Automatically switch between Zoom and Normal view?
Is this possible with a simple shortcut? For some apps i need to switch to zoom display in order to select something on the edges but it is a drag to get to that setting and get back to the app. How are you guys switching?
Or is there an app that can open apps in predefined windows with a specific size? That would be great !
Thanks !
Using a X5+
Jul 5, 2017 21:31:07 GMT 1 aalmans said:
do you mean apps that you can't see parts of it?
yes
Jul 6, 2017 11:39:11 GMT 1 aalmans said:
yes
switch from round display to square one, it is in display settings.
I know. But i was wondering if there was an easier way. Now if i have an app open where i cannot see a part i need to go out of it into display settings, change the view, return to the app make the changes, then potentially go to another app where i do not need the square display, go to display settings again, change it back, return to the second app etc…
It would be easier if any app can open by default per app in either round or square. Not sure if that is possible…
Jul 7, 2017 11:14:33 GMT 1 aalmans said:
I know. But i was wondering if there was an easier way. Now if i have an app open where i cannot see a part i need to go out of it into display settings, change the view, return to the app make the changes, then potentially go to another app where i do not need the square display, go to display settings again, change it back, return to the second app etc...
you can make a short cut with an app, there is mr. float, rover…
Thanks. Didn’t know about these apps. Look like they can only float widgets and not apps. Unfortunately i would need it for Play Store…
Jul 8, 2017 18:16:36 GMT 1 aalmans said:
Thanks. Didn't know about these apps. Look like they can only float widgets and not apps. Unfortunately i would need it for Play Store...
yes, i know with the x3+ i had the same issue with google play store the only app which did'nt work with square interface. use your account on your pc to install apps on your watch that what i used to do with my D5.
Yes thanks. That’s what i am doing now indeed
If you have root, you can shrink and float any app by shortcut to reach hidden corners.
Check out this:
play.google.com/store/apps/details?id=jp.tkgktyk.xposed.niwatori&hl=en
And this:
repo.xposed.info/module/jp.tkgktyk.flyingandroid
Hi, in my NO1 D5 there is no such option to switch from round display to square. I only get this by using Universal Launcher. But this runs buggy on my D5, so it would be great if I could use a (root) app to force some apps to show as “square” on my round D5. I only have root, not xposed, is there any root app to could help me?
Thanks.
Aug 3, 2017 14:48:51 GMT 1 difem said:
no, there is'nt but try Eric's thread about his launcher maybe something can be done to make it more stable with 4.4 watches.
Thanks. I already asked in his thread.
