Hello,
I can connect to the Internet with my Lemfo without any problem by manually selecting wifi network or mobile data using the icons of the menu that you find swiping one time up and one time to the right.
I didn’t understand what happens when you enable both: it is the watch that selects best network available? Is there a way to tell him to select preferably wifi when available, and to connect to mobile data only when wifi Is unavailable?
Jan 2, 2019 20:15:47 GMT 1noidremained said: No need to do anything, it will use wifi when available and only switch to mobile data when the wifi connection is really bad/non-existent.
I can’t seem to get much lem8 data to connect, is there a setting? Phone calls work and messages work. But but no data for web or apps. Thanks
