I ask you if you can help me with tethering. How do you get watch everytime connected to internet?.In the past, i used Bluetooth Tethering Manager to manage watch connection without losing internet (wifi and 4g bluetooth connection from phone)…but now on my Lemfo Lem12 Pro, doesn’t works.
The last solution I’m using is to activate manually bluetooth connection from phone; but everytime I lost connection, I have to enable wifi or bluetooth tethering again.
I did same thing by using macrotools.
Automate, Macrodroid, Tasker, etc.
I used “Automate”. Its easy to use but I can do difficulty things. Now A10 has bug as you know, we can’t show popup dialog some situations, so I can’t use Macrodroid on A10 watch.
If you want to make a connection of BT PAN automatically (server:Phone, client:Watch), Its maybe useful as a reference. I have run this flow for reconnect to BT PAN. (Its not good flow, only for a reference)
I’m newbie of Tasker, so I don’t know about Tasker so much. but I guess Its not easy to make the profile like The “If Screen on, BT PAN becomes on” flow. Because Tasker doesn’t have way to easy make connection and disconnection of BT “PAN” only. (Its not mean Tasker can’t do it, Tasker is strongest macrotool. I don’t know it now …)
At the default, Tasker has tasks of connecting and disconnecting all of BT. but It will kill BT connection of WatchDroid also.
By the way, I can help you about Automate.
In my flow, “BluetoothPAN_byDisplay_V0.1”.
Its important to divide the fiber (fiber means executive portion in the flow), because If the BT is off, BT connection will be false, fiber will be stopped. So I made main loop of “Display on?” and sub flow of "Connect or Disconnect BT " by using Fork block.
In my flow, No.3 “Devices unlocked?” block is not work if you don’t use lock screen. On non-locked Watch, “display on” is equal to “un-locked”. If you use lock screen, the block work waiting untill unlocked. Do you use lock screen?
I checked your flow. I think you are hard working person. Its better than my first flow.
My advice is below;
Unfortunately, in the Deep sleep mode (DOZE mode), Automate can’t work normally, especially Delay block. Please check the “awake device” box of No.7 Delay block. But Its use battery a little. I guess you need 10sec connection after display off, so Its no matter…?
On my Prime2, No.8 Delay block work correctly. You can check the log, where the fiber being now.
You can use “device locked?” block, if you use lock screen. But lock screen will disturb some working of Automate, because security; Eg. I can’t use click and swipe emulation on the lock screen, of course.
Perfect I’m working to improve my Flow share it again.
I have another question to resolve:
I discover that if a go away from BT coverage, Flow freezes and I have to stop and re-connect to fix it.
According to this, I managed to build an automatic flow to fix it using the visibility from notification of watch droid assistant. “If it visible then run Flow, otherwise stops”. The thing is that i can’t pick up the flow…it goes away and return to Automate everytime I want to use pick up. How do you fix this in A10???
Its nice idea! you are nice.
I have two method for your question. I guess you want to use “STOP flow” block. No.1 is smart, but at No.2, you can get knowledge about Automate.
Please use “Fiber Stop” block alternative to “Stop flow”. “STOP flow” needs " flow URI", but we can’t pickup on A10watch and Its different by devices.
Please set variable of “fiber URI” in “Beginning Flow” block.
This way is smart, because we can use the flow in all devices.
You can write directly to “Stop flow” block. Please see the bottom area of the picture. There is “Current Value: flow URI”. All Automate’s block has URI. In this case;
