I made this clockskin and simplfied it for clockskin designers to see how these new features work . Download it , open the .xml file and see how the new features work . Keep tapping the watchface over and over to see the effects .
bg file - you can use any .mp4 file as a background video . You simply drop it into the clockskin folder and it works . It doesnt need to be in clockskin .xml file for it to work .
Array 80 - tap the watch face over and over and the images change until it reaches the end . You can have as many images as you like . I used numbers to keep it simple .
Here is the file
A special thanks to @wahbgh for all his help
              Downloaded, but Dial.xml doesn’t open in WFD or WFDbeta
              It wont . I made it manually . You will have to open it and read it on your Pc . I kept it very simple and tried not to over complicate it
              Good job, Doctor! This one should be helpful for nearly everyone.
              Thankyou . The possibilities are endless of what you can do with these features
              CrAzY !  Very cool ! Thanks for sharing !
              No problem at all . I’m hoping most can understand it . I was going to delete the clock to make it more basic
              Yeah … it isn’t that hard to understand … opens up a huge amount on ideas !  ( Kinda Hate You for that ! )  LoL
here is a test I did : https://drive.google.com/file/d/1UZ_Mf1929s2Azqh4hAPJT2XvWIYbO8-l/view?usp=sharing
              Lol . You can also convert .gif files to .mp4 files online for free
https://ezgif.com/gif-to-mp4
Once converted change file name to " bg " . And drop it into the clockskin folder
              Am i right in thinking you didnt try out array 80 in your demo ? I cannot see it
              Correct … just trying out the mp4 and you have to use a “clear” background
Very Nice … so whatever MP4 you use: Needs always called BG.mp4 … I see …
              Yes . Any .mp4 file and name " bg "
              Or i guess in this case the " background" Is always the mp4
Kinda cool my watch “plays” this … without UL … not sure how many will though …
              Yes . The array 80 images appear on top . And the clock sits inbetween
              Any way to use this in : WatchFaceDesigner ? or only " by Hand "  ?
              You have to add it manualy.  WFD can’t handle it.
              Only by hand . WFD was never completed and all  communication with developer has stopped . So old features never completed let alone new ones
