Aplicaciones y herramientas para lemfo les 1
Solicito de su ayuda, tengo un lemfo les 1 pero no he sabido aprovecharlo, solo le tengo una aplicacion que es con la que sincronizo con mi telefono que es el watch droid  assitant, pero no se me hace muy completa, queria pedirles si hay una aplicacion bien completa para sincronizarla en el telefono.
Ademas queria preguntar si hay alguna aplicacion en el play store para instalar en el reloj o telefono para personalizar, algo asi como un launcher ya que quiero cambiar el modo de verlo pero sin cambiar la ROM original, o por lo menos cambiarle las esferas ya que las que uno puede descargar son muy limitadas
Agradezco su ayuda
Mar 6, 2018 22:20:11 GMT 1 jleonardo1005 said:
PLZ in English:)
  1. yes, you also have M2D or Swapp Link or the stock notifications app the Wiiwatch.
if you mean for also calls you’ll have to flash the firmware which includes the bt calls app but better to ask les1 users about it.
2.yes, there is Eric’s launcher ( ricktop ).
I am requesting your help, I have a lemfo 1 but I have not known how to take advantage of it, I only have one application that is synchronized with my phone that is the watch droid assitant, but it does not make me very complete, I wanted to ask if there is a very complete application to synchronize it on the phone.
I also wanted to ask if there is any application in the play store to install on the clock or phone to customize, something like a launcher since I want to change the way to see it but without changing the original ROM, or at least change the spheres since which one can download are very limited
I appreciate your help
jleonardo1005
yep, as i suggested in my post above you:)
