I bought unbranded DM100 (1gb+1GB) from here: Amazon.com.tr
I wanted to root and use live wallpaper as a system app, and it worked thanks to great help by this website. But because I flashed lemfo roms, the camera is not working anymore. It says cant connect to the camera. I didn’t know only system image should be flashed
When I flash the W variants of both Lemfo and Ticwris firmwares for their 1 gb models, they works fine except camera. But I didn’t check the original firmware before flashing other roms unfortunately.
I need to know if your original firmware is a “D” or “W” type screen.
So I need to know exactly when you purchased it, and where you purchased it.
If you get this wrong you may end up with a pure white screen that is useless.
If this happens you have to be prepared to flash the other firmware version.
This is only possible (if you get white screen) if you have the firmware loaded in the flash tool, and click on the download button in the flash tool.
But - you must have the watch connected by the cable and long press the power button until it reboots.
As it reboots, it will flash the firmware you loaded in the flash tool automatically.
So, on the first flash you can flash the firmware on in “download only” mode and then factory reset.
(Don’t try to just flash the system partition - if you do, it won’t boot.)
If you get the white screen, or “no touch response” - you will need to let me know which version you flashed.
Then you can flash the other package I have linked in “firmware upgrade” mode in the flash tool - using the method described above.
So - which screen do you think you have?
Where and when did you buy it?
For example, any device that has DM or DMN in the firmware name is made in the Domino factory.
Several thousand are produced and then sold to brands like Lemfo or Ticwris and then they are sold under that brand name.
LEM T or Ticwris Max, for example - are also DM100.
Domiwear is the sales brand for Domino and so it is “unbranded”…
Glad to find this thread and this specific Domiwear version of the firmware… like a dunce i forgot to backup the current firmware for my LEMT that i bought from the “official lemfo store” on aliexpress. I tried at least 10 firmwares (lemfo, ticwris, etc) including the one on lemfos site and every single one of them would either give me crazy screen lines (official Lemfo on on their site), or the touchscreen wouldnt work or the camera wouldnt work.
This Domiwear “P” version works perfect and adds some more fun watchscreens and the face unlock function.
