Hi all. The battery of this device if I use it with half-hour navigator drops from 100 to 30. Any suggestions for a firmware that makes it last longer? Thank you
Can you provide your firmware???
I’m Curious, my Zeblaze thor 4 pro will arrive soon…
So I also want to know if there is a Firmware that can helps keep the battery longer!
Aaaaaaaannnnnd another questions!
Do you guys know if I Downgraded my Android system to 5.1 to make BT calling, I could take also a Firmware whose can help not drying my battery?
Regards…
Jan 31, 2019 5:46:17 GMT 2 hashmi said:Jan 28, 2019 19:49:13 GMT 2 trytoon said:
XY_THOR4_PRO_20190104
hi All
i have the same problem with my Thor_S the battery drain very fast.
the firmware: THORS_V08_20171229
THANK YOU
Feb 8, 2019 16:18:35 GMT 2 maxyamamoto said:
I'm Curious, my Zeblaze thor 4 pro will arrive soon... So I also want to know if there is a Firmware that can helps keep the battery longer!Aaaaaaaannnnnd another questions!
Regards…
guys, i do’nt have this watch but basically most of the time somthing causes the draining and most likely it is an app i never had issues with battery considering bt as kw88 pro or the kw99 or i8 or i which all have very small battery. my suggession is to reset the watch and only use it with wiiwatch 2 and that is it to see if you still have issues with battery if so,notify here.
you CAN’T downgrade cos different hardware.
Apr 7, 2019 12:33:18 GMT 2 achref1986 said:
What is the last update of zeblaze thor 4 pro?
Hello,
to all the people who search firmware zeblaze thor 4 pro
I just had the link following a request from the zeblaze sav
this firmware is dated January 4, 2019 and corrects the problem of weak display
I enclose the link that will only be available for 2 days
sorry i’m not used to sorry
cordially
