Neither more or less. The image got mirrored
My LOKMAT doesnāt recognize my sim (and any sim, i tried another already). I tried to turn it off and on, reboot, take off the sim and put it back again, erase to factory settingsā¦ This happened during a running session. Any ideas? Iām so pissed right nowā¦ Third watch in a row (the first and second were the Optimus 2 model from Kospet). And iām stuck with my old Prime (1), which i have tortured for many years and it keeps goingā¦
(Just a sidenote: Iāve turned on my oldie but goldie Kospet Prime, and itās still the best after all these years! It was my daily driver for about 18 months - I loved using it! )
Iām certain this will have been due to moisture from your run . Hopefully it will dry out and start working . I am surprised though as the sim tray is in a good position . Have you tried drying with a bag of rice ?
The optimus 2 and prime 2 dont stand a chance with moisture due to camera position
I had the sim revoved (and the cover also) for a full dayā¦
Maybe longer will work . If the sim connector is eroded then its bad news
Even if cleaning the SIM contacts with a cotton swab will not work as usual, I would try the following instead:
I would fold a piece of blotting paper in half and soak it in rubbing alcohol. Then I would try to clean the metal contacts with this. if salty sweat residue prevents contact, this could fix the problem.
OK guys, i used a compressed air can to blow air inside the sim socket and the 4g signal is backā¦ I also noticed that the front camera has moisture insideā¦ How can i prevent this? I would like to avoid wearing an athletic wristbandā¦Can i cover the sim socket with a tape or something?
Also, itās the first time after many athletic sessions that this happensā¦ And it surprises me that it didnāt happen during September, when temperatures here in Greece were 30-35 Celsius degrees and it happens now, that we have about 20 degrees.
Unfortunately, there are several places where moisture can penetrate. The buttons are also a potential problem.
Unfortunately a watch phone is always going to have issues with damp and thatās why I always advise people to think carefully about using these as fitness monitoring devices.
Like a regular mobile phone, there is always somewhere that moisture can get in - when you think about it.
It would be advisable to try using a sweatband and something to prevent moisture transfer to the watch if you have to use it for this.
It is a constant source of frustration for people and I have started to think that wearing them during fitness activity is just not really possibleā¦
Naturally, you get hot and perspire which means āsalt waterā.
The worst enemy of electronics
A very cheap BT fitness band is probably the best option if using a device for fitness activities is really important.
Or a $600 USD watch might be able to survive itā¦
Iāve never been able to afford the cost to test it personally.
Totally agree . As you know i have tested most for running with terrible results . Sweat and damp air gets into these devices all the time . Since buying a samsung for sports only i no longer take the risk
Thank you all for your responses.
I have a Garmin forerunner 220 (bought 180 eur, 6 years ago), which has the most precise running measurements of all my watches, but it isnāt a phone and it doesnāt support music playback.
I have also a Huawei Watch 3 Pro (bought 400 eur), which has fantastic hardware, i even wear it during swim (with sim enabled), but the huawei software is crapā¦ If only it had android and it would have been the ideal watch (i donāt care about the lack of cameras obviously).
The Kospet Prime is a fantastic watch in terms of durability, but itās hardware and software has got old.
I think i would go with the wristband (although it sucks )ā¦
I have the lem13 which never had these issues as it sit in a case and i just love it and all other watches including the prime and lokmat 7 have gotten corrosion problems which led to unusable watches as there are not also parts for sale, if it was possible to put android 9 or even 10 on the lem13 that would havemade the watch perfect.
Not possibleā¦
But, the whole thing about the LEM13 is that the same can be achieved by putting a watch in a pocket or similar protected areaā¦
The important thing to remember is that the Android watch phone is designed to be a phone watch first and foremost.
Fitness tracking is something added under pressure from customers but the financial cost of effective implementation makes it impossible to deliver for the money.
The 4g signal came back. but the camera diedā¦ i never use the camera, but should i ask for a replacement? Will i have problems in the future with other features of the watch?
If you want to try to get a replacement you should contact the seller immediately.
If you are going to use on your wrist for monitoring fitness activity, you should make a plan to prevent it from being damaged.
I canāt advise you any more reallyā¦
You know what caused it and you are entitled to get a replacement.
How you use it in the future is up to you
