One thing I have noticed is that the GPS seems to be reliant on a Sim card.
With Wi-Fi only, it takes a long time to get a fix.
In my experience anyway.
I have a SIM card and use the data connection. However after activating the high precision in the settings you showed me I noticed a faster fix. I still have to test better . Then I will let you know
Hello, GPS is really shitty on my APPLL 4 Pro. When I have to use it with google, tha I allways disable, and GPS on my old kospet workās like a charm without wifi, sim or googleā¦
I have also removed all the Wiite apps now using ADB. I first removed things like browser, contacts, messaging, phone, etc so that when I installed the Google versions, I would not have two of the same app for these in my apps list. But eventually as I kept removing apps, I found out that everything that I use keeps working if almost all of them are removed. The only ones I seem to need are com.wiite.update for software updates and com.wiite.WiiteCommon for the menu that shows up after holding the power button. I used āpm uninstall -k --user 0 package_nameā inside ADB shell, and to reinstall ones that I ended up needing or to test things, I used āpm install-existing package_nameā since theyāre still in the system partition. In particular, removing com.wiite.power stops the special charging page from showing up which was annoying for me. You can view a list of installed packages by running āpm list packagesā, and adding ā-uā shows the uninstalled ones. Grep and sed also work in the ADB shell. I know what I did removes the watch face display software and all the health apps, but since I prefer using a custom launcher and recents list anyway, I donāt need that part. For the health apps, when I tried to use them they did not seem very good to me in comparison with my Apple Watch. I will try installing Heart Fit and using Sleep as Android, and if those work and sync with Google Fit, this should be a good solution for me. If not, I might install the sleep and heart rate apps again. However, my Apple Watch probably has more accurate health features anyway so I will not be too disappointed if that aspect doesnāt end up working that well.
In addition, I should warn you that since I am blind, I have no idea what using a regular Android launcher like Lawnchair and removing all the Wiite apps makes things look like visually. However, you can always reinstall them with ADB if this removes functionality or does something you donāt want.
I took a break from this for a few months but now that I have more time I was able to get the watch pretty much exactly how I want it. Talkback does not seem to read anything from the watch faces or allow me to switch faces either with the default launcher or Universal Launcher; by accessible I meant usable with accessibility services like Talkback. So I installed Launchair and that works well, and I like how it has both a home screen with multiple pages you can rearrange and an alphabetical apps list. I was also able to root the device with Magisk; even though the watch entered a boot loop several times, flashing it with the SPD Research Tool always fixed it. After installing Quickswitch and the correct Launchair version (12.1 does not work with Quickswitch on Android 11), I was able to change the recents list from the default one to Launchairās, which lets me read all my open apps and easily close one of them or all of them without stopping things like accessibility and background services. The battery life is still pretty good for me even after doing this. If I need to completely force stop an app thatās running in the background, I can use the āForce stopā button on the app info page for it.
With root I can setup any things to made it better, GPS too, but I have to look at itā¦
I have the lokmat appll 4 pro now 2 weeksā¦
no fix after 10min, but gmaps, that I donāt want to use, get position with WiFi, but without WiFi nothing on my appll 4 proā¦
@hans007 have you tried this?
How long exactly are we talking about? More than 10 minutes?
Thatās not easy to answer because there are so many variables for each person.
All I can say is that the best location performance for me is when I am:
- Signed into google services and have unrestricted data enabled for play services.
- Google location accuracy enabled
- Sim data activated
- Wi-Fi enabled
- Background BT and WiFi scanning enabled
- Make sure that you have the most up to date Google Play Services installed.
- Use a GPS app to clear AGPS data and go outside and get a first good GPS lock. This clears any stale GPS info and ensures a faster lock in future.
This is what I do every time I get a new device or visit another country.
Just remember that this will use a lot of power and after the first good lock, you can disable background BT and Wi-Fi scanning and disable Wi-Fi.
The Sim data and up to date AGPS data should ensure a fast lock after the first time.
Hope it works out ok for you ![]()
Everything you say may be right but nothing changes for me. Every time I find myself in a street where there is some taller building, the fix takes more than 2 minutes. I have enabled everything, including wifi and bluetooth. I fear that the GPS antenna is of poor quality. As always āthanks for your adviceā
That does sound rather cumbersome!
Do you get a GPS signal without SIM/WiFi at all?
After a first good lock, you should be able to get a fix without Wi-Fi or Sim card, but it will take longer with no agps data.
Itās important to remember that the GPS antenna inside the watch is very, very small.
Compared to a regular mobile phone, it is tiny.
So, like your mobile - it will struggle to get a lock in built up areas with high rise buildings. More so than a mobile phone.
Same applies with getting a GPS lock without AGPS (Wi-Fi and Sim turned off).
Your mobile phone will also struggle without AGPS enabled, but because the antenna is so much bigger, it will be faster than the watch.
Obviously a clear line of sight to the sky is vital when AGPS is not available.
Since the antenna was moved from the strap to inside the watch case, the performance has been reduced for obvious reasons.
But people wanted removable straps, so there was no way around it.
you can set without sim.
battery life max 12 hours.
Ronald
Holland
hello , is there a way to update the heart rate data on the stock Launcher without opening the apk ? In the universal launcher it is possible instead here not . I would like it to update the beats every time you turn on the screen or after every interval of time automatically. Like it happens with a "com.weatheronraise " apk that a user has developed here on the forum that works great. How about tasker ? Has anyone created such a profile?
Hello. For some reason my lasers are on all the time. With what it can be connected? Checked in the GaoFit application, for oxygen it costs 3 hours, the heartbeat is 60 minutes. Firmware 1.4.
are you with the stock Launcher or with Universal Launcher? As I wrote above, Universal Launcher turns on the green lasers updating the data every time you turn on the display. On my Lemfo it works like this if I use U.L.
I would like to have the same result on the stock Launcher too. Developers please reply ![]()
