There’s nothing left to be done I think. maybe if bugs are found.
Removed the dashes from the date that was ugly if you use month abbreviations.
Was thinking to give the bomb also second animations. Like a burning fuse
How does this (type of) apk differ from those that we used to load onto the KW88?
I’m having problems with my D5 at the moment but you say it should work on that as well?
If the D5 runs Android (4.x I think) it should run without a hitch. It’s installable, uninstallable, without any hooks to the system.
You need to use my alternative launcher method to use it as a WF that shows on powering on the display. Also need to configure some gesture to be able to return from launcher to WF. And I install “Home 2 shortcut” which changes the power button behavior in “press once = home button”. “press twice = power off”
Then you have a fully customizable SW.
Please install and tell me if it works.
@tim_Collins I’m still learning how to program and then how to expand this system.
if you have interesting WF’s publish the links. if I like it, you can ask the designer if he want’s to participate.
@Konto_Nastraty
Switch off gestures in your setup and the digital watch is gone.
I’ve seen the Tissot. Maybe I’ll convert it, but I have a bunch of better WF’s to do first.
Also you cannot just ask for a conversion here. It needs the consent of the designer of the WF before I even consider doing it.
Ok sorry I did not know about it. According to switch off gestures is easy but it would be great to have wake up option and activate tasker with FW isn’t? I feel uncomfortable every time pressing the button to see the time.
