Is it possible to charge the watch with this? The original is huge! besides a 3D print, I am not able to find a dock that’ll fit the original but plenty for this
I know but I wanted info on this model or similar. Has anyone ever tried it or an alternative method? My theory is it should because it’s a similar pin set up just the surface area is missing and from what a few have mentioned, the charger doesn’t sit well on the watch without adapting something to keep it in place which you can do with this
It won’t work because the watch doesn’t have magnets in the POGO pin areas. You will have to use the original. And it works well.
Thanks, I appreciate the feedback
