i don’t know if this is common with the LES1 but the charge dock supplied with the watch isn’t that great at keeping a reliable connection
it seems as if the magnets are not strong enough to hold the dock in place too well for instance picking the watch up usually breaks the connection
are there any alternative charging docks that do a better job and where could i order one from ?
TIA
The dimensions are ok,do not charge battery,I didn´t try connecting in the pc because I bought it to charge in the car.
I bought it because I saw at the end of this video a similar cable but it must be from another smartwatch,not kw88…https://youtu.be/BwojRY59LaU
i have ordered one from the original site www.lemfo.com/pd.jsp?id=117&_pp=135_613
i have ordered the 25 of April …i am still wainting .
I also bought it and they sent me the same one that comes with the smartwacht,not the one with the four contacts at the end of the cable.
I find that the original is not good for charging in the car.
you mean adding “in” the watch?
