The latest official version is installed on your watch. However, there is an A10 version for this watch available in the downloads section.
However, this area can only be reached once you have reached trust level 2.
Thanks for reply
So how i can do to reach second level?
May i think to try download and install the 1.9 version?
The ticwris max s firmware? Of course, you can. But itās not a newer version.
If you are an active member of this community for some time, you will automatically reach trust level 2. Read and write a few posts, give and receive a few likes, be patientā¦
Thatās all.
Hi at all
I am very frustratedā¦
actually i canāt use my kospet note for what i thought⦠so iām very sad
all the apps i want to install on it are incompatible with this android 7.1 version
so iām waiting for android 10 download to have a tryā¦
Otherwise I think it was a failed purchase and will try to resell itā¦
Be patient. You will reach trustlevel 2 soon.
have you tried to download them from apkmirror.com or apkpure.com?
not yet, i will try tomorrow, but i donāt be able to install some apk too.
It wonāt goes
Some apps simply needs a higher Android version. Thatās also why I had to upgrade to A10.
This Is my motivation too
Iām in wait and Hope soon ![]()
Good morning at all of you
Kindly, Pablo11 give to me the access for download the file for upgrade at android 10 versionā¦really many thank to @pablo11
Now i procede
download and extract the 7z file
install on my pc mediatek driver
return the smartwatch at the original manifacturing settings
open the flashing tool v5.2052
select the scatter file into the source folder
then In the drop down menu change from ādownloadā toāfirmware upgradeā
turn of the smartwatch
click on ādownloadā e process start
it ends in few minutes return a big green āOKā
reboot the smartwatch:
new name ofthe watch is DM101
android version is 10.7
Glad you flashed without any problems ![]()
