Is it possible to add Dutch as a language on the new KW88 Pro 1gb/16gb…
Oct 11, 2018 14:26:36 GMT 1 raybodie said:
Is it possible to add Dutch as a language on the new KW88 Pro 1gb/16gb....
it is'nt in the list of system languages? if not, only an upate.
Can you tell me what firmware version you have at moment please?
Buildnr. Kw88pro_V1.1_NHH_B_20180804
KERNEL 3.18.35
it is’nt in the list of system languages? if not, only an upate.
Ja het is mogelijk Nederlandse taal toevoegen ook al niet in de lijst staat met App morelocal 2 zie video.
nacer
Thanks for your post.
I will test this on a watch running Android 7.
Please post in English here because it is an English forum and posts that are not in English will be removed.
Thanks.
Pablo11.
INSTALL OTHER LANGUAGE
Quick steps if not rooted:
Open Google Play, search Morelocal2 and install.
Search on google adb-tools.rar,
expand to c:\adb
goto adb directory cd c:\adb
connect your KW88 Pro with usb cable to your pc
execute cmd
if you are in c:\adb type
Type adb devices (enter)
if you recieve unautorised see youtube wath to do.
ATTENTION if your watch is on his front turn your watch on his back, than you can see a message and anwser yes.
make attention that usb cable stays in contact with your watch
if you recieve the serail and device, then you are ready for the following commands
Type:
adb shell (enter)
Type
pm list packages morelocal (enter)
Type:
pm grant jp.co.c_lis.ccl.morelocal android.permission.CHANGE_CONFIGURATION (Enter)
Go back to your KW88 Pro - start morelocal2, select your language.
I installed Dutch with Belgian keyboard (azerty - dot) works fine.
Attention not all applications are translated in your language but most off all
Succes Nacer and others who wants other language than this who comes with the watch.
See Youtube video
