Actually this is my second project, my first project also on its way. I’m very noob about making a watchface. I hope you like it. Please do not reshare.
After some adjustment, here you go. Its base on edifice 550, credit to Casio corp (http://www.casio-intl.com/in/en/wat/watch_detail/EF-550D-7AV/&lc=id-ID&s=1&m=503&host=www.google.co.id&ts=1508894395&sig=ANTY_L0NJAyUrKAu67jYg633gquDLHDnYw)
This watchface has been adjusted and tested for KW88, since it showing different condition when tested on CSM simulation.
Description :
- The small dial on the right, showing months, it has 2 different length of hands, the shorter will point on month 1-6, the longer hand will point on month 7-12
- The small dial at the bottom, showing days of a week
- small circles with rotating red movement, showing battery level. This is one of the most important indicator that I need on a smartwatch, i don’t want to go out without noticing that the battery has depleted.
- rotating number disc at the left m, showing 24h.
Download link : https://www.dropbox.com/s/2e7bjiddpyyffc5/Edifice%20550.zip?dl=0
