Hi Guys I may be wrong on this topic but is there a an app that can display the face with just a touch of the blank Screen. My PRIME does not work well with arm raising, it’s very hit and miss and I don’t like to keep pressing those weak buttons…obviously there’s no way the watch can be powered on without These buttons. Maybe you know different
My wrist tilt function seems to be working fine but I mostly disable it to save battery life. This means I use the button a lot to turn on the screen but I don’t find it to be weak, but then again I only have the watch two full days so far. It would be nice to be able to tap the screen and wake up the device and hopefully it will be possible to do this in some future firmware update but I am not sure if such a thing is possible. Time will tell.
There is a app that will do this but the battery drain is terrible . Its a waste of time
Yes Andy is correct on this one. I did try it only to find everyone was correct. Very bad battery drain…it’s really not worth installing.
Macrodroid might do it, perhaps, in its settings, there is an option to watch for shaking, from there, it can inlock the screen, but, the battery drain obviously would increase, although less than the app previously mentioned above, which keeps the back light on, and uses a dark filter ro obscure the screen
I tried with an app named " shake screen on off" , free version from play store, works really well, the impact on battery life is noticeable, but not outrageous, I like to have many things running in the background for customization purposes, and overall I get a 2.5% per hour drain in iddle, for me, if a device can last more than 24 hours in normal use, then It is ok, I no longer try to extend battery life at the expense of sacrificing features/functions
