I tried charging it via usb slot on my pc, and also via regular 5V 2A samsung smartphone wall charger…
And it charged from 5% to 27%, and i connected 4hours ago…
It was charging ok few days ago… i dont know whats making it charge so slow now…
Jun 4, 2017 20:11:38 GMT 1wh1t3l10n said: I tried charging it via usb slot on my pc, and also via regular 5V 2A samsung smartphone wall charger...
And it charged from 5% to 27%, and i connected 4hours ago...
Any advice?
Tyvm
(latest fw on my thor, no custom launcher)
have you tried charging it when it is off? if problem continues you'll have to reset the watch and see if it helps because most likely an app causing the slow charging. plz notify if problem continuses even after reset might be a problem with the battery.
Jun 4, 2017 20:11:38 GMT 1wh1t3l10n said: I tried charging it via usb slot on my pc, and also via regular 5V 2A samsung smartphone wall charger…
Any advice?
Tyvm
Didn't tried while it's off... But yesturday it charged ok to 100%... I'll se what will happen on the next charging...
