Watch Base creates skins for Samsung, perhaps the credit should be Samsung but I have cited WB…
CREDIT: http://WatchBase.store
Hey Doubledad - great face, the first I’ve downloaded in months! Am I seeing a problem? The little silver hand bottom left, pointing to either AM or PM is, for me, currently pointing upwards, halfway between the hour and minutes of the digital time box. It’s currently 1.35 PM here so I guess it should be pointing in the same direction as yours in the image … ?
And a secondary but less important question, is the ‘altimeter’ bottom centre supposed to do anything?
Should add I’m using a Lem14 with V 1.3 Beta running.
Thanks for the input Keith… This watch requires the Universal Launcher and I suspect you are using the Standard Launcher, right? With UL, the AM-PM pointer works properly. Further, the altimeter is not functional.
I wondered if that was the problem, but as you hadn’t specified UL in your blurb I hoped it would work. Never mind. Still a great face.
