2.4.8 published : ASSAULT now working.
Happy Christmas !!
Hi Erick
I unistalled and cleared all,even some task killers apk,i installed the new launcher again and give its all authorisations and then i reboot the watch this is the skin after reboot
I add again the first widget and give its the authorisation again and all work fine,after some hours the screen became white and the skin became this
If i clear all on stock task manager (long press button and push on the right)all work fine but sometimes i have the same problem,even for me in Assault the word Weather overlaps with actual data
Hi Friend,
First of all Thank You very much for this app. I really like it.
2ndly I have a problem with the latest version. I have installed it from play store and now all my watch faces are scaled to a lower level i.e. they cover half of the screen and the remaining half remains black. Can you please fix this or guide me how to do it?
I have LEMFO LES1
Dec 27, 2017 8:48:26 GMT 1mohsinshahzad said: Hi Friend,
I have LEMFO LES1
Looks like you activated the square zoom mode of your watch…
Hi Ricktop, your launcher is amazing. It give much better look and feel for our cheep Chinese watches.
I use it since yesterday on my Finow X5 plus. So far I have notified two small issues I have not been able to solve :
.watches are not displaying. Black screen
heart rate is not working. I tried with heartontop: with the default launcher it work. Start your launcher and reboot : No HR. Back to défaut launcher : HR is OK. Edit : Solved by installing “setting search” then in application -> All -> Heart Rate -> force stop.
Do you think you can add in your application release version somewhere in the app. Just to be sure we are on the last release before reporting something.
Hi, first of all thank you for this amazing launcher!
I cannot call the watchfaces since I cann only see a black screen that must be shut of by clicking the power button several times. I have a Diggro DI01 (5.1 stock, 1 GB RAM). Should I use an older version to solve the problem?
Fantastic launcher, with great watchfaces available… Works great on my H1… apart from the heart rate, but I guess I need to find the proper tweak to have continous HR monitoring. How do you do that, and how will the battery survive with HR monitoring all the time ?
Is there a possibility to have a access to a task manager (and killer) on swipe-up ?
Last, I don’t use voice command, so I’d like to change the swipe down option to get to the sport tracker start screen from the H1 original UI. Is there anyway I can do this ?
Dec 28, 2017 12:38:03 GMT 1igork said: Hi,
Fantastic launcher, with great watchfaces available... Works great on my H1... apart from the heart rate, but I guess I need to find the proper tweak to have continous HR monitoring. How do you do that, and how will the battery survive with HR monitoring all the time ?
I have a Finow Q7+ and the launcher starts up in the 120 DPI mode which is just a little too big for my display. When I try to make it smaller and I touch the DPI button it goes to 160 DPI. At that point the “uninstall me” button overlaps the DPI button and I can only uninstall the app. I can never get the display smaller. My watch is NOT set on the zoom display mode. Is there a way around this or is this a defect in the app on my watch.
Dec 28, 2017 17:19:30 GMT 1davidrb said: I have a Finow Q7+ and the launcher starts up in the 120 DPI mode which is just a little too big for my display. When I try to make it smaller and I touch the DPI button it goes to 160 DPI. At that point the "uninstall me" button overlaps the DPI button and I can only uninstall the app. I can never get the display smaller. My watch is NOT set on the zoom display mode. Is there a way around this or is this a defect in the app on my watch.
If you have a setting/display/app Adaptation, then use it... Otherwise i need to change the way of setting the DPI in my app...
I don’t have the app called adaptation and I can’t find it. I did try version 2.3.5 and I can get it to work. The overlap still exists but not as bad so I can get to 80 DPI which looks good on my Q7+. It doesn’t have all the features of the newer versions so I will keep looking here for an update. Thanks
I have LEMFO LES1
Looks like you activated the square zoom mode of your watch...
No I haven't. I confirmed it first. Version 2.0.7 works fine for me without any issue but the latest one does not cover the whole screen. If i turn the square zoom on, the wathface goes down to the lower left side. And if I turn it off, it come to the middle of the screen but covers on 50% of the screen.
Did you reboot after going from square to round. I have to reboot each time I change from one to the other one.
I have install this on Zeblaze Thor S, but position of the skin and other menu is not right. I also try to full menu., but still not right…, Try to restart and boot still the same.
Is there any same condition with this type of watch, or there are setting/trick for this ? Any help will be so great. Thanks.
Dec 29, 2017 9:01:12 GMT 1Mauldi said: I have install this on Zeblaze Thor S, but position of the skin and other menu is not right. I also try to full menu., but still not right.., Try to restart and boot still the same.
Can you post à screenshot of your watch ?
Here's I attach, screenshot for full screen mode. Other menu is perfect, besides main screen looks of the clockskin
It is very strange : the skin is shifted : I suppose you tried other skins. I tried to reproduce it by playing with zoom and dpi without success. I am afraid I Will not be able to support
Dec 29, 2017 18:53:49 GMT 1Mauldi said: Here's I attach, screenshot for full screen mode. Other menu is perfect, besides main screen looks of the clockskin
uninstall all and clear dati of launcher then reinstall without zoom and reboot
