UMSW Smart Watch - Hopefully edited and rotated right! https://youtu.be/mgkKuVR8sLg Specification: 1;
Specification:
1; Stainless steel full round smart watch, bright HD display
2; Independent intelligent systems to support the application synchronization
3; Real-time information push, screen automatically gets brighter when you raise your hand
4; Heart rate monitor, pedometer sports, open healthy living
5; 3ATM waterproof design, to meet the daily use
6; Your intelligent assistant, a hundred beautifully designed dial updated
7; Standard strap design, with more personality
Main Function:
  • Model No: UMSW-E65
  • Screen Display: 1.39” AMOLED capacitive touch screen
  • System: Independent Android 4.3
  • Resolution: 400×400,287PPI
  • Processor: 1.2GHz dual-core low-power chip
  • Memory & Capacity: 512M + 4G high-speed flash memory
  • Sensors: heart rate, G-Sensor, gyroscope, pressure
  • Functions and reminder: Replaceable dial, sports pedometer, heart rate monitor, application store, screen bright when raising hand, call reminder, SMS reminder, weather, calculator, calendar, clock, audio, games
  • Bluetooth: Low-power Bluetooth 4.0
  • Battery capacity: 300mAh polymer battery
  • Charging method: PogoPIN charging cradle
  • Case Material: austenitic stainless steel 316
  • Color: rose gold, steel original color, black tungsten steel
  • Strap type: Stainless steel strap, leather strap
  • Size: 54.644.514.2mm (excluding crown)
  • Weight: 68g
  • Connect your phone: Support Bluetooth connectivity IOS 7.0 and above android 4.3 and above Smartphone
The software on this looks quite nice and I like that they’ve tried to get rid of the black ring around the amoled. I’d say straight on its almost invisible from sight. Pity the specs are a step back.
i think he maybe talking about android 4.3.
I actually don’t consider 4.3 a step back. Everything I’ve seen so far about 5.1 makes it more difficult to work with as a watch OS. I actually preferred the X5 4.2 OS … but that’s me :slight_smile:
looks like the i2 with 3 buttons. My next watch is the ticwatch2 going on sale 10.30 pm tonight adelaide time.
@john_gully nice - let me know how it goes John :slight_smile:
@john_gully Thanks for the info! Just ordered an Onyx version.
