yes, that’s correct
yes, if you want you can install either supersu or magisk after you have flashed twrp_patcher.zip
yes, that’s correct
Many thanks for the information.
I hope everything works, the image is indeed suitable for the Diggro DI01.
If I have problems I will contact you again.
Read more: /post/28642/edit#ixzz5WIPXHZUU
I can not open the link
“Problem with dowloading img file. SP tool write: PMT changed for the ROM. Please select Format All + Download.”
have the same problem
with the option ‘firmware upgrade’ comes another error.
Partition [preloader] No image file Exist!
How did you solve it?
Hello everybody.
Do yout think this twrp is compatible with my kw99 version 2Gb ram and 16GB rom.
It’s a mtk6580
