Sorry, but I’m still trying to memorize which forum member owns which watch. Help me briefly: What is your watch?
Lemfo LEMP ![]()
A ok, now I found it. I’ll have a look, but you might have to wait for the weekend. I’ll try to do it earlier, but atm I’m quite buissy.
Thanks buddy.
Yeah I assume it’s not a big deal but I couldn’t solve it for myself, although I tried it.
Another araytype is needed. WFD can’t handle it, it has to be added manually at the XML
Forget what I wrote above. It’s much easier.
I tried to insert ANGLE -45 inside drawables image 09 and 10 in a couple of ways but didn’t work.
Something like that:
<drawable>
<rotate>3</rotate>
<angle>-45</angle>
<mulrotate>1</mulrotate>
<centerX>-99</centerX>
<centerY>0</centerY>
<name>image10.png</name>
</drawable>
Well it seems the forum’s editor doesn’t shows well the code here when I paste it…
Only the image of the hand needs to be realigned. in such a way that the tip points upwards. No need to change anything else.
Yeah, the pointer and his shadow (images 09 and 10) in a -45 angle
Just correct this. For example by importing it in WFD. Any Image program will work, too.
Not the rotation angle inside the .xml file then?
Only the image you say?
Exactly. Wfd doesn’t write the angle in the XML in this case. It just adjust the image.
Then I’ll try it with watch face designer (didn’t use it before) and tell you later ![]()
Thanks men!!! ![]()
You are welcome. ![]()
