This is the problem I have with APN settings with kw88, anyone has any solution? Thank you
I t normally means your provider is not in the APN data base. It can be added but you will need root access. You will also need the 900 or 2100 band for 3g.
Thanks for the info. There will be some way to get root access on this watch?
Yes. We are still working on the recovery for this one. @Ciro_Danise almost has it but there is a flipped screen issue at the moment. If you can wait for this it would be better than the brute force methods.
It sounds great with a custom recovery, but in the meantime you could tell me which program can give root this watch? It is my first watch phone and I have no idea.
Hi , Any update on this one ? , i am using a Global Roming Sim Card , and i want to add my settings but there is no option .
No tengo datos
I dont have datos in my smartwatch kw88 my sim card have Internet but mi kw88 dont work
