All of the A8 watches have problems with some clockskins
If I were to personally recommend a watch in this price range, it would be - despite some weaknesses - the S13
Agreed. Great watch for a great price
What is S13 ? A new smartwatche ?
I installed Universal on my GT200. When I change the keyboard layout to square, the watch faces become square. What should I do to keep the watch face in a round position and not change to square? Please advise.
I tried installing watch faces on the GT200 in many different ways, even with a RAR file, but the contents of the zipped file are still scattered and go to the gallery. I donāt know why it goes to the gallery folder. I think the problem is with the gallery folder, which was unintentionally introduced to this project. Does anyone know how to solve this problem?
Itās actually normal for watch face image files to be stored in the gallery. This is the case on every watch. Clockskin files should be visible in the āClockskinā folder.
To view these watchfaces, you will most likely need the Universal Launcher on this watch. You already have it installed. If youāve done everything correctly, youāll see a pulsating analog clock as your watch face. If you still see the stock watch faces instead, the Universal Launcher isnāt yet selected as the default launcher.
However, this is most likely required on this watch to display custom watch faces.
Universal Launcher installs and runs on my watch without any problems. But I actually wanted to install the theme in the main menu of my watch without the need for Universal Launcher because it is easier to access the system and the watch app. Please guide me if you find a solution for this issue. Thank you.
Iām afraid thereās no other solution. On some of these A8 watches, using custom watch faces only works with UL.
Very true. Creating a clockskin folder is not enough. UL must be used
Even using UL All dials do not work perfectly. For example, a graphigan indicator of battery status on a watch with A8 will not display. But most dials work
That is correct and as there are many buthered versions of A8 you dont know what you will get
Does anyone have an Android 9.1 ROM for the GT200 watch that I can use to replace 8.1?
This GT200 watch model has two versions of Android: 8.1 and 9.1, with Android 9.1 having better performance.
Most of the so called A9 devices are faked A8 watches. But I donāt know this one.
True. The GT200 is a upgrade to the GT100. Both A8 and as you said the A9 versions are fake
This is my watch modelā¦see in the video how the zipped folder is unfolded
Uploading: VID_20251013_130339.mp4ā¦
If you want to share a video, upload it to your GDrive and share the link. Whatever, not needed in this case.
This peculiarity of this watch is one of the reasons why it isnāt supported here, like many A8 and A9 watches.
In my research, the A9 version supports shell operations and zip installation easily⦠Thatās why Iām asking the forum for the A9 ROM to replace 8.1. Can anyone give it to me?
