hi i wanted to ask how can i use the shake arm motion do display my watchface and not the other standard screen face. i have non rooted les1 and no launcher, looking for a non battery draining way.
use Eric's launcher and you'll be able to see the WF that you've picked.
i dont know how to savely install eris launcher, iam not very tech savy, where can i find it? will it drain the battery more then the normal launcher?
no, and you install it as you install any akp:) you download the apk to your pc and then you copy it to your watch and from downloads you open it and install:)
read Eric’s thread and you’ll get all the help you need. if not ask me freely:)
i have battery drain issues tried everything from the othenr “battery drain Thread” didnt work. are there watchface that dont drain the battery ?? what else to do , can i exchange the battery , buy somewhere a replacement battery ??
Jun 26, 2017 17:58:35 GMT 1 chrys said:
i have battery drain issues tried everything from the othenr "battery drain Thread" didnt work. are there watchface that dont drain the battery ?? what else to do , can i exchange the battery , buy somewhere a replacement battery ??
you had battery issues with Eric's launcher?
I had battery issues with Eric’s launcher too. Have a Zeblaze Thor.
Also tried the shake-n- wake app from one of the other threads. Same issue. Went back to default and get a day out of the watch.
The other two lasted about 5-6 hours from full charge.
i try to install erics launcher but where do i find the option to enable my watchface when i shake? . i downlaoded the version 2.2.3
check Eric thread he explain what to do to see the WF you want. as i understood there should'nt be any battery issue with Eric's apps.
