S99 fake android 13 Watch
Yes google calender. Doesnt work on any android 8 watch but works fine on this
GPS tested with google maps / my running app and GPS test. Locks quick and strong
@Dr_Andy_Vishnu Does the stock launcher have clockskin function watch faces mate?
I mean, when you first turned on the watch, did it have a clockskin folder on the storage?
Thanks mate :+1:
This is a different custom OS than all the other watches that you mentioned.
Those others you mentioned (and many other models) have hard coded custom calendar, SMS and many other apps, which causes installation failures for some Google apps :frowning:
It’s very cool to see another provider stepping up with a solution that actually allows the Google eco system to work with no problems. :+1:
Who is the brand @Dr_Andy_Vishnu
It’s that to see if we can get these supported, firmware and dev samples etc….
No and No mate
Ok thanks.
Just checking that the watch faces we use are not usable, unless you install the UL etc.. :+1:
Anyone have any idea how to tell if you are buying an s99 or an m99. They seem to look identical.
Here is where I was looking to get it from.
I just found this on AliExpress:
5G Full Netcom S99 Smartwatch Android 13.0 Smart Watch With 190° Rotating Camera NFC Compass IP67 Waterproof Google Play Store
The M99 is listed as A9 which its not and the newer S99 is listed as A13 which it is not. Both A8
By the way,
Just to be clear full 5G Netcom is not possible. They justify saying that because the Wi-Fi connection can support both 2.4ghz and 5ghz. 5G cellular is not possible in watches yet. Far too much heat.
NFC is restricted to travel access etc. Cannot be used for tap and pay situations. So my advice is to ignore what the advertising says and search for real reviews of the watch model before you think about purchasing.
Yea the specs looked fake. That’s why I figured I would come here and see what you guys had to say about it. ThanksšŸ‘
Also is there a significant difference between the m99 and s99 in usability?
I have no idea, never even looked at these because we can’t support them.
But, @Dr_Andy_Vishnu may be able to help…
i believe s99 is asr processor which is garbage
and only W527 and very new ASR supports 5g wifi, w377e/8641e is only 2.4g
NFC in all watch is mifare claassic 1k , UID is not rewriteable
Agreed. :+1: :+1: :+1:
There is no denying this watch for £ 50 isnt bad at all. Especially if you want google and all google apps to work. I use with the new version of UL which completes the job
Also agreed :slight_smile: If it does what you want and are happy with - no worries :+1:
I bought the lokmat version of the m99 and it works great​:+1:
LOKMAT APPLLP 6 Max Android Smart Watch Phone AMOLED Screen Rotating Camera 4G Phone Calls Wifi Video Calls Fitness Tracker
I have both the M99 and S99 they have a lot of different problems but i dont regret purchasing either one, not really any good for Strava or Google fit. I still have not figured out doing bluetooth calls on the S99 ,not really much on how to set up , wasnt sure if th sim in phone then use watch bluetooth call or vice versa. they both work well with wifi ,had problems getting sms to work on S99 so would just turn it off and on, when i sent a message it would come up not sent, then when it diodnt say anything it would take forever to get to the person. even without a sim in both they are still good looking watches.
it is not possible to do bluetooth call without either modifying the kernel of the watch or have root access on the phone it is extremly difficult
There appears to be some way of doing this with the tethering apps that were/are now being used by the brands. Does not work unless the app is installed on the phone though.
I believe the DT_Ultra_2 and DT_Ultra_3 had this kind of set up. Just thought I’d mention it if anyone is interested.
It is only possible if you are willing to compile the Bluetooth driver from source
In gsi system I can not do it if your driver do not have this feature
