(The battery indication may be different depending on the motor of each watch, to correct it you must adjust in rotate battery - Angle / StartAngle In the application CSM)
Thank you very much, great master! I’m very uncomfortable to ask you, but could you change this dial a little? make the numbers entirely white, not from dots … and add the number of steps …
@Sergio_Paulo1 i am install this faces now…but…See for yourself! the size of the picture is smaller than the display, it is noticeable, and there is also no picture clarity, it is very obvious (((
@Sergio_Paulo1 thank you my friend, I will try today … unfortunately I do not know how to do it myself … could you make another face for me? I’m ready to pay for your time …
@Sergio_Paulo1 I put a new face on the clock, the size is excellent, but the clarity of the time and the weather is very low…you can replace the font more thin and clear?
