Hy all together i have one more question about D5+ together with Iphone 6…
I used the app "watch helper " and want see all messages from my iphone screen…
So thats work fine some time, but after 1 or 2 hour there comes no messages more… the watcht and the iphone says “connected”
if i make bluetooth off and on by the watch it works again some time
Have some one a idee
Dec 4, 2016 11:31:59 GMT 1webbel said: Hy all together i have one more question about D5+ together with Iphone 6...
I used the app "watch helper " and want see all messages from my iphone screen...
So thats work fine some time, but after 1 or 2 hour there comes no messages more... the watcht and the iphone says "connected"
Greetings Uwe and a nice sunday
i do’nt think you’ll find a better app for the iphone, if you live in north america you can use pplconnected or pushbullet.
yes thats true, but i think the probleme is not the app, the D5+ cancel
someting and wait for reconnect…, than works again for some time!
Is this with a android phone the same or works for show messages
Dec 4, 2016 13:40:53 GMT 1webbel said: yes thats true, but i think the probleme is not the app, the D5+ cancel
someting and wait for reconnect..., than works again for some time!
better for long time?
uwe
go to settings - saving power and unmark what is marked there.
same to me … and I have all save battery off… ?
battery saving nothing is marked? if so the problem is with the Watch Helper, try to clear data and stop the app and try again better app is the M2D.
I’ve reset the watch, it’s the same. After a laps of time, it don’t work.
I instal “raise to wake”, after 1h, the watch don’t turn ON when i turn my hand…
Feb 5, 2017 22:18:23 GMT 1webert said: I've reset the watch, it's the same. After a laps of time, it don't work.
I instal "raise to wake", after 1h, the watch don't turn ON when i turn my hand...
KW88 does support the motion--raise to wake. You don't need to install the app. And if reset the watch doesn't work, you may need to do a wired flash.
KW88 supports this motion, but don't display the selected watchface on my kw88. Can it?
