Probably a stupid question but I don’t know how to change rings for incoming call on X watchs. If I go in settings-sound I only see the default rings. Where should put .mp3 file to let the watch see them and let me select one of them as an incoming call? Thx
There is a folder Ringtones on your watch. Copy your own ringtone ( for example an *.mp3 ) into this folder. Then you will find this tone in your settings.
That’s the way I use to do it on all my phones, but I’m afraid it doesn’t work on my X1. The only way I’ve found to do the job is installing an app like zedge or something similar
Es file explorer will allow you to select any file on your device to use as a ring tone.
If zed works we should be able to do that too. It probably can be done with settings search
@Gerhard_Kuehl it worked simply by putting .mp3 in ringtones directory like any other Android phone. I have k9/x3
