NEW IQI 13 Firmware with the same face engine as the KW88 available now
NEW IQI 13 Firmware with the same face engine as the KW88 available now here:
I only got this last night. I have flashed it and it seems to be fine.
PLEASE PLEASE read the update guides before you do this. They are on the tech forum with the firmware. In this instance you should choose the firmware upgrade option in SP tools. It will wipe ALL YOUR DATA !!!
http://roundandroidwatches.proboards.com/thread/19/iqi-i2-i3-firmware
Thankyou very much bro!
This was what I was really waiting for. =D
the sactter file has error 8417, can you resolve this?
@david_df , I’m a little lost in installing the rom on my iqi i3, did you follow any tutorial? Could you tell me one?
You must download the ROM and extract the files to the new folder on the desktop
Secondly you should download the flash sp tools: http: //http://spflashtool.com/
Finally you open the program and select the scatter file of the option and browse in the rom folder the “mtk6580 scatter_file” file is the text file.
Then you click on part of the download with the smartwatch off, but before you go to the development section and accept the bootloader option and you will enjoy the new version
@Renan_Wesney how did you do it I don’t know how
@david_df can you made a video showing how to do it
Many thanks @david_df ! I managed to do the procedure, and everything is working correctly, my smartwatch is updated = D
@ByFactura It’s very simple! I will try to explain as simple as possible to you how I did it.
  1. download and extract to a new folder the flash tool
  2. download and extract to a new folder the iqi i3 firmware update
  3. On the iqi i3, go to the options / aboutwatch / developer options and activate the developer option, and turn on the OEM unlocking (the boot loader) (5th option I think)
  4. On windows, open the flash tool, and, just change the scatter loading file, click choose and look for the file “MT6580_Android_scatter.txt” select it.
  5. Select, on the left, below the option of authentication file, the option “firmware upgrade”
  6. Now connect your smartwatch to your PC USB port.
  7. Now, click on the flash tool, on the download icon at the top.
  8. Now, turn off your smartwatch (Be very careful to don’t remove it from usb)
  9. will initialize in the flash tool the installation on your smartwatch. (5 minutes)
  10. When an OK icon happens in the middle of your PC screen, remove the smartwatch from your PC and turn it on.
  11. will be like the first time you turn it on (10 minutes turning on)
im sorry i really dont know how to doit
do you have to put the option of dowload only or which one
Don’t you guys ever read the guides? You can end up with a dead watch if you don’t read !! All the information you need is in the forum with the firmware.
I will link you to it again http://roundandroidwatches.proboards.com/thread/51/smartwatch-ticks-video-guides-flashing
I have flashed this myself - there are no scatter file errors and it was an easy process.
And here is another guide https://www.youtube.com/watch?v=5CxDF2pkdCQ
Thank you it works good
@ByFactura that’s good news :slight_smile:
But the one whit snakes is not there
And on watch face is not working
I have found out that they have changed the dpi of the screen and it has caused watch faces to look tiny. Even in Erics launcher. I am working with them (sinsoft) to fix it. In the meantime - if you can’t stand it you can flash back to the december firmware.
hermano, i did everything you said but i used the download option instead of the upgrade firmware because i thought that s what you were mentioning on your post, should i now upgrade firmware or just cry, what can i do. btw i got some dead pixel since the download-
