This watch face refrigerate your Smartwatch…
ANIMATED…
ANIMATED…
Hi . Is the face designed to work with UL due to the animation ? Or have you used array 62 . The reason i ask is some faces designed for UL can brick watches when UL isnt installed . I havent had chance to test it . If the only animation are the fans rotating it should be okay
