My kingWear kw88 shows signal with sim card in but no calls come in
My kingWear kw88 shows signal with sim card in but no calls come in nor out the devices and its rendered unavailable in cellphone use. How can i get this watch to work as my second phone?
Check your IMEI number and ask in the tech support forum.
http://roundandroidwatches.proboards.com/
How do i check this IMEI bruv??? Have no idea…
@yawe_martin_leroy
So you have an IMEI - which you can find by going to settings/about watch/status/imei information. You should have an IMEI SV number in there as well.
I have removed those posts to protect your number
Which sim card have put in the watch? What is your provider - Vodafone, Optus etc etc ?
I’m in the UAE and its a DU simcard.
That’s the msg i recieved from where you told me to ask.
How can i do that mister?
Exclude double quotes
It does work on this one bro. I’m out of ideas now
I now have to delete this as it is illegal to have this on our community.
Sorry. - and it won’t fix his problem.
@yawe_martin_leroy you landed on the wrong page. You need to sign up and become a member of the site I sent you. You went to Proboard support :slight_smile:
Your IMEI and SV number are correct. It maybe an APN issue which you find in cellular settings. You need to edit the APN to be the same as your phone.
The correct link for the support forum is
Okay then lemme try that bro. Thanx … will letchu know if it works
