I have a stock Kronos Blade Genesis and have loaded a pile of mp3 music tracks. Question, how do I play in continuous random shuffle?
I had to go back and look but found it again. You have to go to the Music App. Open it and you will see the current song at the very bottom. Tap on it and it takes you to the actual player. (This is different from the player screen you access sliding the watchface to the right.) At the top you have a menu and two icons. The icons are for shuffle and repeat.
I added a screen shot from my watch. If you slide the screen all the way to the right you can find playlist functions.
That worked…thanks
