I put the firmware 2017 11 22 then once configured the SmartWatch I inserted the SIM in the rear compartment but the data connection does not happen, APN I inserted it right unless there is another firmware version for the one with SIM card
Please turn it off and on again.
does not work
Phone is working, mobile data not? Are you sure that mobile data is enabled in the settings?
I managed to put the firmware Z10-YFZ-V13-20180601 … yay!
So it’s working now?
with this firmware I am noticing that the keyboard has the most spaced letters, then also the menu has some icon that changes (example: switch platform has 2 arrows instead before it had a symbol with a drawing and also Connect Phone to the symbol before it was with the drawing . in the notifications section it is the same. now let’s see if the data connection goes by putting the APN of I mobile … No it still does not work, although I have put the correct apn
