I followed the instructions on your video and it all went fine, I go the “OK” at the finish of the flash but the touchscreen still doesn’t work.
Aug 26, 2018 4:52:13 GMT 1 bugsbunny said:
Hi,I followed the instructions on your video and it all went fine, I go the “OK” at the finish of the flash but the touchscreen still doesn’t work.
1.which firmware version did you try?
- did you choose upgrade in sp flash tool?
The many instructions we see posted or mentioned on this forum, on flashing these watches, are often confusing and sometimes contradictory. I would be beneficial to me and probably others if a basic set of instructions were provided on Flashing these watches that explained when to use the different functions. For example: When do you use (1) Format All & Download (2) Firmware upgrade (3) Download only. Also when to use the preloader and when not to use the preloader. This would be an excellent starting point to eliminate a lot of the confusion and hopefully issues people have flashing their watches. When you know what to use it sounds simple and works well. When you don’t know it can be confusing and problematic.
you are RIGHT and i will add instructions to the video or even do new one with these instructions.
Aug 27, 2018 2:12:20 GMT 1 soniasophie9697 said:capt jon
