Lemfo lem6
Aug 10, 2018 20:10:23 GMT 1 koush said:
no, you should only make sure that cellular data is on and not off, in every spacific app it has Restrict....that should stay grey cos it will limit the usage of data. are you talking about data connection of 3g or wifi?
I don’t have a sim card installed, I just use wifi, and it on wifi that is greyed out. I don’t have cellular data, probably because I don’t have a sim card.
Koush
Aug 11, 2018 7:34:50 GMT 1 koush said:
if you are on wifi that means you should'nt have any restricted issues that only applies to cellular networks i never had prolems with wifi, did you make sure that you get notifications even when the screen is off?
Yes I do get notifications when the screen is off. The LEM6 firmware have the same problem of not updating the weather on the watch face?
there is'nt auto update for the weather cos it will drain the battery faster that is why only manual updates.
For auto update you need my launcher. Look YT channel tutorial.
I have installed your launcher, still not auto updating for weather, actually it does not update manually either. Any suggestions or settings I need to change. I have watch the tutorial and can’t see anything there, unless I missed it.
Koush
Aug 15, 2018 18:27:27 GMT 1 koush said:
Koush
does’nt update manually? did you make sure that you are on wifi or 3g (data connection)?
I found a bug on this subject, it will be corrected on 2.6.1.
Ok thanks, I’ll wait for the update.
Soniasophie my watch updates the weather app, but it does not show on the watch face as updated, just to clear things up.
Koush
Aug 16, 2018 9:07:56 GMT 1 koush said:
Koush
try with stock face and then with custom face, for me it works fine.
***if i’m not mistaken the firmware of the lem6 is done by Finow and if so…then yep…it is crap, i had these issues with watches from finow which on watchfaces did’nt update, your solution is only to use Eric’s launcher.
Thanks, I will wait for Eric to update the fix. I have tried it with stock watch faces and custom watch faces and it they do update when I manually update the weather app.
Koush
hi everyone…i have a lem6 how can i improve on the battery on the watch.
Sept 12, 2018 17:25:56 GMT 1 martin2162 said:
hi everyone...i have a lem6 how can i improve on the battery on the watch.
try to make sure that the watch never turns off always charge it when it is on, if you do'nt have sim in the watch leave it on airplane mode and turn on wifi, gps, bt as much as you need. reset the watch, make sure to turn off sync and updates. do'nt use wrist gesture.
Aug 16, 2018 19:57:21 GMT 1 koush said:
Koush
The whole watch is made by Finow. Everything.
Lemfo purchase bulk quantities and have their brand name put on the firmware and packaging.
I will see what I can do about getting this watch supported by us and at least get the latest firmware…
koush - Eric has updated the launcher. It may be worth testing…
i`ve bought this watch recently.
After last OTA update /firmware is dated from june 2018/, option checkbox “use for internet” under paired devices bluetooth connection settings cannot be ticked.
It is impossible to use internet from paired smartphone via bluetooth tethering.
Any fix, solution?
Tnx in advance
Guys,
any idea how to solve the Bluetooth tethering which is not working with last OTA update from June 2018?
I`ve tried with software reset and reset via factory recovery with no success.
Then i flashed with ROM from Dec-2017 using SP tools.
On that version and one next one which dates from Mar-2018 (obtained via OTA update) Bluetooth tethering it working, but those two are lacking BT call feature.
It`s a definitely some issue with latest ROM version.
Sept 22, 2018 16:00:41 GMT 1 aca80 said:
you connected the watch for BT calling so most likely you can't use bt tethering while doing so. it is like you want to connect same device twice.
Tnx for clarification.
I was thinking that way so i tried disconnecting from phone in BT call app and unticked checkbox use for call under phone`a bluetooth settings while ticking checkbox next to internet access.
It can`t work.
So with the BT call introduced in newest ROM it`s impossible to use bluetooth tethering?
It can`t work.
you can, just disable bt calls (on phone) when using internet access.
