lemfo lem x
kyone
No it doesn’t help on the A7.1 watches…
Hi Guys,
Can you please provide some feedback to Lemfo regarding the false advertising of the IP rating?
en.wikipedia.org/wiki/IP_Code
The IP67 rating is applied to most of there smart watches and I don’t think any of them would survive being submersed in water to 1m for 30mins.
I would make an educated guess that the watches are actually rated to IP52 with some luck during testing.
To truly get IP67, watches really need the new fancy esim chips rather than the nano sim cards, and touch buttons. [It is possible with rubber gaskets but usually they have a limited number of operations.]
edit: I watched a mr ticks video and saw that this does have a rubber grommet on the sim cover, and your tear down shows silicon around the mic and speaker.  So I would hope the Lem X would have a higher IP rating than the Lem 7, but I still doubt IP67.   I should have posted this gripe on the Lem 7 forum which i read first.
Мало того, что они не могли выдержать погружение в воду, на моем Lem7 экран перестал работать нормально, после того, как я ехал на мотоцикле под дождем. Я намокла.Я до сих пор Финов X5Air в них я хожу в любую погоду и мою руки не снимая часы и все нормально.
Sorry mate, English only on this forum. Otherwise we can't help you.
Dinatron was just agreeing with me "Not only could they not stand the immersion in the water, on my Lem7 the screen stopped working normally after I was riding a motorcycle in the rain. I get wet. I still have Finos X5Air in them, I walk in any weather and wash my hands without removing the watch and everything is fine."
That sucks Dinatron
In other news,  I just ordered a Lem X and dont ride bikes so hopefully it will be OK.    Lemfo has a special for the next 10hrs or so on Aliexpress and with coupons it cost $248 AUD (ish) including GST and free slow shipping.
grrrr
I would hope the LEMX holds up reasonably well with moisture after all the improvements they made for the production watch.
The sim tray has double rubber gromits and is such a tight fit they supply a special lever tool for opening it.
The speaker and microphone are sealed with silicon and the body is one piece cast.
The screen is also sealed in place with silicon.
I still class this as “splash proof”.
However, even after all this - I personally would not treat my watch as waterproof - smart or otherwise.
It’s just not worth the risk, and I don’t often find myself in a situation where I am in water and need a watch…
Thats fair enough mate but personally i prefer “ fish fingers “ with brown sauce :+1:
Oct 15, 2018 14:27:46 GMT 1 grrrr said:
just do like I did put plastic film screen protector and you will be fine I did post some pictures I think the best option is the square film protector for the Samsung gear fit
Sept 30, 2018 19:37:56 GMT 1 pat14 said:
hello or I can order a charging cable for a lemfo Lem x
you can get it from www.aliexpress.com/item/LEMFO-Extra-Charger-Cable-for-LEM-X-LEMX-LEM7-LEM6-LEM5-LEM5-Pro-KW88-KW18-LF18/32875231557.html?spm=a2g0s.13010208.99999999.259.3d973c00awX4qX
LEMFO D’origine Magnétique Chargeur De Charge câble pour LEMFO LEMX Montre Smart Watch LEM X smartwatch
s.click.aliexpress.com/e/bhEnLuKz
Oct 16, 2018 19:45:31 GMT 1 pat14 said:
LEMFO D'origine Magnétique Chargeur De Charge câble pour LEMFO LEMX Montre Smart Watch LEM X smartwatch s.click.aliexpress.com/e/bhEnLuKz
The link you provided does not go to the cable in question? The link in the previous post does.
Le lien que vous avez fourni ne va pas au câble en question? Le lien dans le post précédent fait. Utilisez l’anglais s’il vous plaît.
Hi
Can someone help me? On lemfo lem x when i use bluetooth with wiiwatch2 all notifications pushed to the watch are only vibrate. I tryed everything but cant make them ring. Pls help
Watch cam without leather strap butt at list the display is ok.
Please where I can buy original silicone strap for lemfo lem x ?
One more question:is you sim cover like scratched ?
Very bad battery duration here…:neutral_face:
Oct 18, 2018 16:11:31 GMT 1 arovaris said:
Very bad battery duration here....😐
You should factory reset your watch.
Aliexpress may have straps - search for it there.
Where did you get the watch?
It comes with both straps and the sim cover should not be scratched.
Oct 17, 2018 12:41:11 GMT 1 sfa said:
Hi Can someone help me? On lemfo lem x when i use bluetooth with wiiwatch2 all notifications pushed to the watch are only vibrate. I tryed everything but cant make them ring. Pls help
Have you checked sounds are enabled in settings? Also check that Watch and connect watch has access to notifications in advanced settings. I use Heads Up Notifications from the Play Store. It works well.
Just curious where did you buy the watch? If it came without the leather strap which strap did you receive? Like Pablo said it comes from the factory with both leather and silicone straps. The reason I ask is because if the Sim Cover was scratched, and it didn’t have both straps, it sounds like you may have received a returned or used watch.
capt jon
Exactly where I was going with this :+1:
I’ve tested on my LEM X and no sound for BT notification, only vibrate. It looks like the BT connection does not use sound or is it because of Universal launcher ?
