(problem solved)Dear membres, My LEM5 completely black out, after installing a face watch does not restart, it froze. :-[
I was about to flash the firmwear, witch is a bite complicated! and according to the factory, they did not recommend that because it may cause problems with the buttons.
Then i try to play with the buttons, and then i find out the solution, there is a
With the middle button i did the normal on and them off, after that i press continualy the bottom button during, maiby 2 minutes until shows the menu were you can reset with factory firmware. I could not believe but it works, and my watch works perfectly.
So before you try to flash the firmware, try this.
very important, even if nothing happens wend you press the bottom button do not give up be patient and the menu will appears.
Feb 13, 2017 20:43:03 GMT 1jonybigode said: Dear membres, My LEM5 completely black out, after installing a face watch and it does not restart, it froze.
Can you please help.
is it still black screen? did you try disconnect and reconnect the battery? if so and still a black screen you need to flash your watch with the stock rom, what did you do that got you to this point?
The watch seams to restart but at some point frozes, and stays with the LEM5 info until run out of battery!
Feb 15, 2017 19:10:44 GMT 1soniasophie9697 said: is it still black screen? did you try disconnect and reconnect the battery? if so and still a black screen you need to flash your watch with the stock rom, what did you do that got you to this point?
ok, you’ll have to flash the stock rom again, download it and flash it:
