Available in my blog.
Watchface Features: Analog time (hour, minutes and seconds hands). Day. Weekday dial. Battery percent dial. 10 seconds dial.
Tap options for compatible watches: Tap in the day or in the weekday dial to open the Calendar. Tap in the battery percent dial to open the Battery Options.
This watchface, inspired in a model from Edouard Koehn, combines two different styles. On one hand we have the elegance of the pattern in the dial and it’s dark blue color, and in the other side we have the modernity of the fonts used and the hands for the main dial and the sub-dials.
The result is an elegant and at the same time modern watchface that you can wear in any situation, fromm casual ones to more formal ones. Whatever it is, this watchface will definitely attract attention to your watch.
IMPORTANT NOTE: The tap options in the version for Android 10 ONLY works with the stock firmware, and NOT in the different beta “International FAW firmwares” developed by Full Android Watch and Wiiteer, because some of the apps used changed from one version to another, and others disappeared. Some of them may work, or not, in those firmwares. Keep this in mind if you’re using any of those firmware versions.
Video Preview:
