My updated KW88 works very well, except for two things:
1. The upper "status" screen shows that the phone is not connected, even if it is, and I receive notifications.
2. When I do receive notifications, it does not vibrate, only lights up the screen. Yes, it is NOT set to "Silence". Yes, in the "Sound" menu the option of vibration on incoming calls is enabled. Yes, the vibration motor works: it vibrates in other instances.
Any help will be appreciated.
there are sometimes updates that it better to reset the watch after.
i have a similar problem but reversed: it vibrates a lot. When i receive a notification from the phone the kw88 vibrate two times with a gap of 1-2 seconds in beetween. Any help?
