kw88 'screen on raising' and 'always on display'
Is it possible to change the default plain digital watch face for the ‘screen on raising’ gesture to a custom face on a KW88?
I would have the same question on ‘always on display’ Can a custom watch face set for these functions and if so how?
I understand this probably affects the battery life but I am curious if it can be done.
szega
most likely will be:) about watchfaces you should see the watch face you’ve selected to be on when you use wrist gesture. what is the date of your firmware?
You Can use my launcher for that, look our YT channel tutorial.
