KW88 Camera not working
Hello
I have a constant problem with KW88 camera. I cant open camera app(“Can’t connect to camera. Please make sure to close other apps that may use camera or flashlight.”) and any other app using it. I tried hard reset(from settings), it did not give anything. What’s stupid, after reset I found out there is turned on Developer Settings, and it is crashing when I try to turn it off.
Please help, cant use Snapchat
Feb 6, 2017 22:31:08 GMT 1 hypixus said:
Hello
try with Settings Search to disable the camera and then try to turn off the developer settings.
Hello
How do I disable it if it does not work in any app?
I found an app called like you said, but in apps there are no system apps showed.
yes:/ i've noticed on my s99a that it is NOT the same as on the D and the X series watches, i also do'nt have a way of seeing what consume and how long battery last much of settings is missing:\ that means only with root system apps can be disabled but till now was'nt able to root the watch.
yes:/ i’ve noticed on my s99a that it is NOT the same as on the D and the X series watches, i also do’nt have a way of seeing what consume and how long battery last much of settings is missing:\ that means only with root system apps can be disabled but till now was’nt able to root the watch.
Perhaps, good news for you - Today, I downloaded KingRoot from their page(newest) and it worked immediately.
thanks, will try.
