Is it any way to measure body temperature with watch ? By software or any other way?
No, this is not possible.
you could try something like this just for the fun of it:
keep in mind that its equations are made to estimate room temperature and not your body temperature, so it will probably be a bit off(somewhere in between your body temperature and the ambient temperature). And anyways I wouldn’t rely on something like this for telling if you have a fever or something as it only gives an estimate
May the infrared heart rate sensor converted to read temperature by software if any? My finow x7 have infrared sensor for heart rate reading as per watch specification. I had read some where, infrared temp reading equipment without touching the body.
Thanks for reply.
