Thanks for the clarifications @Jam-gino . I know that the little issues I am facing are obviously related to the launcher and not to the face itself. Anyway, it is absolutely fabulous and definitively my favorite one. Thanks again for having applied all the suggestions I sent you. You’re the best !
Thx!! as a suggestion… the creator of the program that is compatible with both models. or in his default a converter for the model kw88
Yes, @Jam-gino , I’ll check with Eric and Rod if they could fix this. Thanks again.
Ok…would be nice a new version of the program 100℅ compatible with both models. and improvements added…
Where can i find the download link ? i only found the PNG files.
Also, is it working on 2.0.7 or only 2.0.1 ?
I don´t see the skins, just the three images.
someone has had to delete the files. now I upload again. tell me where I download the program compatible with kw88 and finow x5 plus
Uploaded files
@Eric_Crochemore The download link is back online on this post. The battery level does not work on 2.0.7, but works on 2.0.1. I did not try the versions in between. Ideally, it would be great to have the battely level working under a patched 1.0.7 version because we would then have also the heart rate and steps count available and the only missing info would be local temperature. Thanks a lot Eric.
@Jam-gino Since it is not yet woking 100% correctly on kw88, would you please explain us what should be the correct behavior of the three bottom icons (hand brake, battery and fuel). Thanks Jam.
believe to remember:
1-the icon of brake to hand. the light in the 99℅ 90% of the battery.
2-the icon of the battery… the light with the battery below 40%
3-icon of fuel… the light with the battery to less than 20%
New version is available, it should solve the issue. Let me know.
new version of program clockskin?
Yes both 2.0.8 and 1.1.8.
Donwload link?
Thank you very much @Eric_Crochemore . It fixes the issue and I can now fully enjoy @Jam-gino dashboard face. Thanks a lot to both of you.
The two downloads are .apk
There is no update in the program clockSkinMaker i have the .exe version 1.5.0.0
That is compatible when designing directly with both models?
