I have a x5 (and several other types) sadly the firmware isn’t really mature and does have bugs in it, which probably will never be resolved.
So, I did some testing to see if the watch would be useful for me.
the goal for me was (is) to have a messaging device around my wrist, so that my wife, family and friends can sent a message via whatsapp (or similar service). I usually mis messages because i am not glued to my mobile phone all day.
My setup is as follows :
Finow X5 with the latest firmware.
Whatsapp
chatsim unlimited sim card.
It would be nice to get the messages as soon as they are send, but the x5 disconnects the 2g /3g / wifi data link as soon as the screen goes to sleep. If I have the “conspire screen on” function enabled then the 2g/3g datalink will be disabled and you have to go into the network settings to enable it again. So that is not going to work for my.
I discovered that without the “conspire screen on” function enabled, the 2g/3g datalink will reconnect in about 15 second. the same will happen when you receive a sms. So I told my wife that if it is urgent she needs to send a sms and then continu via whatsapp. If it is not urgent then I still receive the messages when I check the time on my watch by pressing the middle button.
I set the screen timeout at 30 seconds, the 15 seconds is just to short for reconnecting.
I use a chatsim unlimited card because it gives me unlimited chatting in about 150 countries and I do travel a lot for work.
last week I could test it in russia and it became my primary way for communication. you can also buy “credits” for multimedia so you can make whatsapp audio calls and sent / receive pictures. etc.
To use my whatsapp account on my “normal” phone, I put the X5 into wifi hotspot mode and connected my phone to it. It works like a charm for chatting. typing on a X5 is not so easy as on a galaxy note 4.0.
So the combination of a X5 and a chatsim unlimited gives me a small and working device to communicate around the “world”. It took some work and testing but I am happy with it. Maybe it is useful to you.
If you plan to use a chatsim please consider using my coupon code during activation CAM5YLAL This will give you and me 1000 multimedia credits. If you don’t us a coupon code you won’t get any.
Also don’t register 2 cards on the same account, you will not get any credits for that, I found out the hard way.
The last thing about the X5 that I had to solve was the connecting pins for charging and connecting. If it is warm and you sweat a bit the pins start to rot away very quickly. Not sure it this is a production fault, but i will become a problem very quickly.
I have a background in watchmaking and goldsmithing so I tackled the problem by gold plating the pins and now they are protected. you can buy DIY gold-plating solution and if you follow the instructions it works fine. You can push the copper pins gently out of the black socket and gold-plate them completely, just make sure that the surface is smooth and fat free. I plated them about 12 minutes a piece. and pushed the pins back in the black socket. now they stay shiny without corrosion.
I am not sure if all of the x5’s have this problem but it would make our watches unusable and it not why we buy them for.
