Great Job i love it ! i managed to change the days of week in English… i hope you dont mind … but i need your help as the numbers are a bit bigger beside the name date … can you help me ?
@Alexandros_Sigalas Hello, is very simple, the name of the days are in a picture, for example, the Moday picture correspond to “clock_skin_weekday_mon.png”, you only need to open in Photoshop this picture and modify the image, you can replace with whatever other thing.
Hola,quiero estrenar mi lemfo lem5 plus con esta esfera,¿pero seria muy complicado cambiar el logo de audi por otro?
@VOLUSIAS no, es muy facil, solo tienes que abrir la imagen con el Photoshop o similar y cambiarlo, es un archivo png
Gracias,se agradece tu atencion. Iba perdido antes de encontrar tu canal de YouTube. Saludos y sigue asi.
Thank you for the reply ! I did what you said and it worked thank you!! now…i want to use the same way for the numbers beside the day. which numbers should I change to be smaller? I placed thundercats on it with Photoshop
@Alexandros_Sigalas Hello, this numbers are in a picture for each one, now I don’t know what is the name because is a picture for number from 0 to 9, and there are another group of this numbers for the hour, the heart rate, etc. you only need to know what is the name of the date numbers group, to know that you need to open the file XML and deduce it, now I have not the face with in this computer and I didn’t remember the files group name.
Una maravilla de reloj. Yo no puedo ver el porcentaje de batería en Y3. Gracias. PD: Thx for link Casper69.
@Blacker_68 I made one good man this dial. Now I have a charge percentage. If interested, write to me - kobra39@gmail.com
@Casper_69 Yes. I write to you. Thx a lot.
Where is the skin file… I didn’t find it… Not able to download the skin…
@Onda_y_Particula , @Juan_Lopez or someone else, can you share another link of the original red one? The link on the post is broken. Thank you.
@Alexandros_Sigalas , could you share a link to your version with days of week in English, please?
Please change the updated Skin with everyone
Hola, puedes poner enlace de descarga por favor?
