How to use WiiWatch with LES1, THOR and others
If you experience connection problems try to remove all pairings you did between the watch and the phone beforehand. It seems the BT LE is most likely to work if the watch is not paired before.
Only disable the packages I mentioned in the first post. If checkmark stays red you might have a BT 3.0 connection instead of a BT 4.0 LE connection.
I installed WiiWatch on a Galaxy S7 and a MI 6. Both work fine.
Best
DrGo
simonepda ;:  Could you please check one thing? You wrote the connection status on the watch stays crossed red for you. Mine is green checkmark. Can you try to unpair the watch and then reconnect only using the WiiWatch app?
Let me know If the watch connects and check marks appears.
Best
DrGo
all: Please note: Do not pair watch and phone manually. Let the WiiWatch app do this. See updated initial post.
Oct 6, 2017 11:36:19 GMT 1 mante80 said:
Using Watchdroid solved my issue.
Details there:
/thread/1620/les1-android-phones-bluetooth-issues
Thanks Man! Watchdroid is fantastic! Now my LEMFO LES1 is perfect. I have 22 hours of active bluetooth connection!
Oct 11, 2017 23:13:09 GMT 1 drgo said:simonepda ;:  Could you please check one thing? You wrote the connection status on the watch stays crossed red for you. Mine is green checkmark. Can you try to unpair the watch and then reconnect only using the WiiWatch app?
Best
DrGo
If uploaded.net does not work,  it's blocked in your country. Change DNS server to PC with 8.8.8.8
I tried matching it with an iPhone.
Followed by the procedure, I get the green check mark on your watch’s connection status page and the notifications work, but when the bluetooth connection goes down, it does not resume anymore. I’ve been paired with the Connect Phone app on watch.
Thanks anyway for everything.
Unfortunately on iPhone no smartwatch does not go so well, except Apple watch
