hi guys
i downloaded last update and after a time watch was restart and now have a boot loop and cant start, what should i do?
plz someone explain clearly…
can some one explain in english lang?
how i can flash stock rom with spflashtools?
hey
im found a way:
worked for me!!!
Apr 20, 2017 15:28:42 GMT 1 benyamin said:
can some one explain in english lang? how i can flash stock rom with spflashtools?
very easy: ***watch should be off and not connected to computer till i write so.
- download the stock rom for your watch.
- download sp flash tool: androidmtk.com/smart-phone-flash-tool
- make sure drivers are installed.
- extract the zip file of sp_tool and open it.
- go to scatter loading and locate the stock rom. it should end with txt and open it.
- remove the v mark from preloader.
- press download and NOW connect the watch (turned off) and flashing should start and when finished you’ll should see a green V mark.
