Hi! I have a problem with battery on my kingwear kw88.
Hi!
I experienced battery drops from ~30%, ~70% and today from like 97% to zero instantly over the 4 days time.
It started happening the day after software update. Now i have KW88_CS1_B_GSM_PHT_20161104.
I don’t know the cause.
I’m sending the picture from today. Like I said from almost 100% to zero. I was watching a movie, looked at watch and then again after like 15min and it was dead. you can see i started charging it after some time. it was at 4% at the time of taking that picture.
i really hope you can help me,
Thanks in advance
When i had kw 88 had the same problem… Which charger are you using? Is it 2A?if yes try using a 0.7A or 0.5A one… For me the slow charging helped to retain more battery.
Thanks, it seems to work now that i changed from Apple’s 1A charger to Samsung’s 2A. thanks for pointing out that the charger was the problem
I had the same problem yesterday and i always used computers usb to charge w88, and all happened after updates.
Last update dran the battery very fast… you must downgrade
How to downgrade?
https://plus.google.com/115348728328756782496/posts/Qx8wnDcr7eC
This ist the best firmware for me. Very stable and battery last very long
