Hi, i could need some help. Does anyone knows how do I Factory Reset the No1 D5 smartwatch? I installed some New watch faces from the origine page and after I choose one it Shows me only Black Screen and doesnt react anymore not even let me to Reset it thru menu i cant go in i See only Black Screen and i cant Turn it of and on Does some one knows somthing and could help me with this problem. Thx
Issue discussed several times. Use the search bar on the left and look for “black screen” you’ll find some answers.
Unfortunately, I’ve done the same thing today. I think that the only solution is reflash. Am I right guys?
Start here: https://www.youtube.com/watch?v=RLH4voR5FZg
Then after you’re bummed that you now need to flash, go here: https://www.youtube.com/watch?v=7lSZMQ6zdN0
If you still have problems, jump to here: https://plus.google.com/u/0/communities/109827242607524552712/stream/68925e2d-2913-494f-9b25-0cd7e74ac0f2
My happened to me the same thing and at the end I could fix it as follows : Press and hold the center button and the lower button until a menu opened in Chinese. In one of the options MenuN saw the words EMMC and thought perhaps refers to a wipe of the phone memory and so it proved. Thus , the clock has been reset to factory settings and is running again !
